To transform an object by specifying exact values
  1. Using the Select Objects tool , select the object that you want to transform.
  2. Choose Window > Show Enfocus Inspector or click the Show Inspector button to display the Enfocus Inspector.
  3. Click the Position category.
  4. Do any of the following:
    • Move or scale the selected object by changing the values in the Position & Size area:
    Box
    Meaning
    Lower Left
    distance between the lower left point of the object and the lower left corner of the page
    Size
    height and/or width
    Upper Right
    distance between the upper right point of the object and the lower left corner of the page
    • Stretch or rotate the selected object by changing the values in the Aspect Ratio & Angle area:
    Box
    Value
    Result
    Aspect Ratio
    > 1
    stretched vertically (h > w)
    < 1
    stretched horizontally (h < w)
    Angle
    positive
    rotated clockwise
    negative
    rotated counterclockwise
    • Scale, rotate or flip the selected object by changing the values and clicking the buttons in the Numeric Transforms area:
    To...
    Proceed as follows:
    Scale an object
    Do one of the following:
    Enter a value in the percentage box and click .
    Select Scale 50% or Scale 200% from the Fly-out menu.
    Rotate an object
    Enter a value in the degrees box and click .
    Select Rotate 90° Counterclockwise or Rotate 90° Clockwise from the Fly-out menu.
    Flip an object
    Click to flip the object left or right
    Click to flip the object up or down.
