To select similar objects
The Select Similar Objects tool  lets you select multiple objects on the same page which have the same attributes. This tool can be useful if you want to change objects in your PDF document which are similar.
  1. Click the Select Similar Objects tool .
  2. Select an object in your PDF document. This can be either a (part of a) graphic or a text segment.
  3. The Enfocus Inspector will open and display the relevant attributes of the selected object.
  4. If necessary, deselect one or more properties to expand your selection.
  5. Do one of the following to select similar objects:
    • Click the Select Similar Objects button.
    • Double-click the selected object.
    All similar objects, i.e. objects with the same selected attributes, will be selected.
