To create an Action List that changes the page layout of a PDF document
  1. Using the Enfocus Action List Editor, create an Action List that looks as follows:
    Select odd pages
    Select objects inside region (Attributes: Use Trim Box. Select objects inside region)
    AND
    Select first page
    NOT
    AND
    Move page content (horizontal: 5.0 mm, vertical: 0.0 mm)
    Select even pages
    AND
    Move page content (horizontal: – 5.0 mm, vertical: 0.0 mm)
  2. Click the Fit Page  button to view the pages on the complete media size and to see:
    • The trim size
    • The page’s trim marks, if any
    • The page’s registration marks, if any
    • The page’s bleed, if any
    • Color control strips, if any
  3. In the Enfocus Processing Panel, select the respective Action List and click Run.
    PitStop Pro will apply the Action List in the following steps:
    Step
    Action
    1
    Select odd pages
    2
    In the Attributes pane, specify: Use Trim Box. Select objects inside region.
    For more information about page boxes, see Page boxes.
    3
    AND
    4
    Select first page
    5
    NOT
    You use the operator NOT to exclude the first page from your selection, because it should remain unchanged.
    6
    AND
    You use the operator AND at this point to combine the selections of steps 1 and 2 with the exclu­sion of step 4.
    7
    Move page content 5.0 mm horizontally
    This change moves the page content 5 mm to the left.
    8
    Select even pages
    8
    9
    AND
    10
    Move page content – 5.0 mm horizontally
    This change moves the page content 5 mm to the right.
