To save an optimized Certified PDF document
  1. Open your Certified PDF document in Adobe Acrobat.
  2. Choose File > Save As.
  3. Click one of the following buttons:
    • Copy and Save. Create a copy of the Certified PDF document. You can select this option to save your Certified PDF document on a different location. The size of the PDF file will increase slightly but you can still save snapshots and use the roll-back mech­anism in this copy.
    • Certified Full Save. Creates an optimized Certified PDF document: the file size will be reduced significantly but you can no longer save snapshots or revert to previous states of the PDF document. The history information about previous editing sessions, however, will be maintained.
    • Save UnCertified Copy. Creates a regular, “unCertified” PDF document. The file size will be reduced significantly but you lose all the benefits of working with Certified PDF documents.
