To resample a single image
  1. Using the Select Objects tool , select a pixel image.
  2. Choose Window > Show Enfocus Inspector or click the Show Inspector button to display the Enfocus Inspector.
  3. Cick the Image > Resample category.
  4. Do one of the following:
    • To downsample an image, select Resample above and specify the threshold resolution in dpi. Only images with a resolution higher than or equal to this threshold resolution will be downsampled.
    • To resample an image up, click to clear the Resample above check box.
  5. Select a resampling (interpolation) method and specify the resolution (dpi) to which the image should be resampled.
  6. Click Apply.
