Example: changing the properties of line-art objects
For example, suppose you have a line-art object in several PDF documents. You want to change the following properties of this object in all of your PDF documents:
Figure 1. Changing multiple properties of an object in multiple PDF documents.
This job may consist of a number of sequential tasks. These individual tasks can be grouped into one Action List, which can then be applied to a range of pages in one or more PDF documents or to complete PDF documents.
Illustration
Action
1. Select the fill color of an object.
2. Change the selected fill color of an object.
3. Select another fill color of the object.
4. Remove the selected fill color of the object.
5. Select lines of an object with a given line weight.
6. Change the selected line weight.
