Using ICC profiles in multiple instances
There are various instances where you can specify ICC profiles in PitStop Pro. These instances are, in order of precedence:
  1. You can tag an individual object.
  2. You can use ICC profiles in Action Lists and Preflight Profiles, and Action Lists can in turn be embedded in Preflight Profiles.
  3. You can specify source and target ICC profiles in the Enfocus PitStop Preferences.
    For example, if you use an Action List or a Preflight Profile to tag all images in your PDF document with ICC profile A and some of these images already were tagged individually with ICC profile B, it will be ICC profile B which will be maintained.
