To use a QuickRun
  1. Open a PDF document.
  2. If the QuickRun you want to run is part of the Favorites database, you can click the button of your choice on the QuickRuns toolbar, or use the assigned shortcut.
  3. Otherwise, you can open the QuickRun panel, select the QuickRun you want to run, and click the Run button.
When the Quickrun has finished, a report or the Enfocus Navigator may appear, depending on your Enfocus PitStop Pro Preferences.
See also Using the Enfocus Navigator and Viewing and interpreting reports
