To lock a Preflight Profile with a password
  1. Open the Enfocus Processing - Preflight panel.
  2. Double-click the Preflight Profile you want to change.
    The Enfocus Preflight Profile Editor will open
  3. Navigate to General > Permissions category in the Enfocus Preflight Profile Editor.
  4. Select a permission level in the Profile is drop-down menu:
    Restriction level
    Meaning
    Not locked
    None of the settings of the Preflight Profile will be locked. Anyone can change any setting.
    Partially locked
    Everything is locked, except for the actions you allow using the options underneath
    • Disable all fixes
    • Disable Sign-off
    • Other processing settings.
    Locked
    Nothing can be changed. You can only select the Preflight Profile and run it in your PDF document.
  5. Enter a password and confirm it.
  6. Click OK button.
