To find and replace text:
  1. In the Adobe Acrobat X, navigate to PitStop Pro > Object and click the Enfocus Find And Replace Text option to open the panel. Or navigate to Tools > PitStop Edit and click this button to open the Enfocus Find And Replace Text dialog box.
  2. In older versions of Adobe Acrobat, navigate to Plug-Ins > Enfocus PitStop Pro and click the Enfocus Find And Replace Text to open the panel. Or navigate to Edit > Enfocus Find And Replace Text .
  3. In the Find And Replace Text dialog box, type the text you want to search in the Find textbox.
  4. Select the Case sensitive checkbox if you want to find the exact word that you type (i.e., upper case or lower case).
  5. Select the Current page only checkbox to restrict your search to the current page of focus only.
  6. Choose the Select partial text objects checkbox if your search query is only a part of a whole word.
  7. Click the Next button to perform the search, the first instance of the search term will be highlighted when found. Continue to click the Next button to find all instances of the search term till the end of the document. When the search has been performed till the end of the document, a message box appears displaying the message Text search has reached the end of the document. Click OK button in this message box and click the Next button to continue the search from the beginning of the document.
  8. Alternatively, you can click the Previous button to search from anywhere in the document to the beginning of it.
  9. If you want to replace the search term with another word of your choice, type the word in the Replace textbox. Click the Replace button to replace a search term which has already been highlighted or click the Find & Replace button to replace the currently highlighted search term and find the next instance of it.
