Integrate with imposition software
The problem
  • Many production companies in graphic arts receive native page layout and illustration files from applications such as Adobe InDesign, Illustrator, or even MS Word
  • Often these native-application files need to be converted to PDF for print production, distribution or other processes
The solution
With this solution, Switch routes files to and from existing imposition software, then to print or RIP queues:
  • Jobs enter the flow via a Submit Point and are then sorted by imposition intent.
  • Jobs to processed by a hotfolder-based imposition solution are routed to the correct input hotfolder. Keeping the Switch job prefix allows and metadata associated with the job to be maintained after imposition.
  • Wide-format jobs are routed to an imposition app created by an Enfocus partner. After the app imposes the job, it is routed further in the flow.
  • Switch routes the imposed jobs to the intended RIP based on metadata associated with the job.
The benefits
  • Seamless connectivity between imposition and production.
  • Keep your jobs moving in a consistent, reliable and efficient way.
  • Use your existing imposition solution.
Flow elements and modules used for this case
Switch
Switch
Client module - Allows users to access Switch workflows from a browser. Learn more.
Metadata module - Make use of job data to automate decision making. Learn more.
Imposition software - third party imposition solution. Learn more.
Pdf
Folder - used to receive, route and collect jobs in a flow.
Connectors - used to establish pathways in a flow and apply decision making based on job properties or metadata.
Are you ready to revolutionize your automation?
Switch gives you the power and freedom to automate your way. Get in touch with an Enfocus reseller to find out how.
